Fortsetzung der Diskussion von
Home Connect Local: Bosch, Siemens und Neff lokal in Home Assistant, eingerichtet per Anmeldung:
"home_assistant": {
"arch": "x86_64",
"dev": false,
"docker": true,
"hassio": true,
"installation_type": "Home Assistant OS",
"os_name": "Linux",
"os_version": "6.18.52-haos",
"python_version": "3.14.6",
"timezone": "Europe/Stockholm",
"version": "2026.10.2",
"virtualenv": false,
"container_arch": "amd64",
"supervisor": "2026.10.3",
"host_os": "Home Assistant OS 18.3",
"docker_version": "29.7.2",
"chassis": "vm",
"run_as_root": true
"custom_components": {
"powercalc": {
"documentation": "https://docs.powercalc.nl",
"version": "v1.26.1",
"requirements": [
"numpy>=1.21.1"
"awtrix": {
"documentation": "https://github.com/MiguelAngelLV/ha-awtrix",
"version": "0.7.0",
"requirements": []
"ultra_card_pro_cloud": {
"documentation": "https://github.com/WJDDesigns/ultra-card-connect",
"version": "1.10.0",
"requirements": []
"alexa_media": {
"documentation": "https://github.com/alandtse/alexa_media_player/wiki",
"version": "5.17.1",
"requirements": [
"alexapy==1.32.0",
"wrapt>=1.14.0",
"dictor>=0.1.12,<0.2"
"hacs": {
"documentation": "https://hacs.xyz/docs/use/",
"version": "2.0.5",
"requirements": [
"aiogithubapi>=22.10.1"
"ha_washdata": {
"documentation": "https://github.com/3dg1luk43/ha_washdata",
"version": "0.5.8",
"requirements": [
"numpy"
"material_symbols": {
"documentation": "https://github.com/beecho01/material-symbols",
"version": "2026.07.08",
"requirements": []
"area_manager": {
"documentation": "https://github.com/olli-dot-dev/ha-area-manager",
"version": "2.6.1",
"requirements": []
"extended_openai_conversation": {
"documentation": "https://github.com/jekalmin/extended_openai_conversation",
"version": "2.0.3",
"requirements": [
"openai>=3.10.0"
"integration_manifest": {
"domain": "home_connect",
"name": "Home Connect",
"codeowners": [
"DavidMStraub",
"Diegorro98",
"MartinHjelmare"
"config_flow": true,
"dependencies": [
"application_credentials",
"repairs"
"dhcp": [
"hostname": "balay-*",
"macaddress": "C8D778*"
"hostname": "(balay|bosch|neff|siemens)-*",
"macaddress": "68A40E*"
"hostname": "(bosch|neff|siemens)-*",
"macaddress": "38B4D3*"
"documentation": "https://www.home-assistant.io/integrations/home_connect",
"integration_type": "hub",
"iot_class": "cloud_push",
"loggers": [
"aiohomeconnect"
"quality_scale": "platinum",
"requirements": [
"aiohomeconnect==0.39.1"
"zeroconf": [
"_homeconnect._tcp.local."
"is_built_in": true,
"overwrites_built_in": false
"setup_times": {
"null": {
"setup": 0.001101506408303976
"wait_import_platforms": -0.6054998761974275,
"config_entry_setup": 15.045262758154422
"data": {
"716030397307015617": {
"ha_id": "",
"name": "Kaffeevollautomat",
"type": "CoffeeMaker",
"brand": "Siemens",
"vib": "TQ723E03",
"e_number": "TQ723E03/01",
"connected": true,
"status": {
"BSH.Common.Status.InteriorIlluminationActive": {
"value": false
"BSH.Common.Status.OperationState": {
"value": "BSH.Common.EnumType.OperationState.Inactive"
"BSH.Common.Status.RemoteControlStartAllowed": {
"value": true
"BSH.Common.Status.LocalControlActive": {
"value": false
"ConsumerProducts.CoffeeMaker.Status.BeverageCounterCoffee": {
"value": 629
"ConsumerProducts.CoffeeMaker.Status.BeverageCounterCoffeeAndMilk": {
"value": 18
"ConsumerProducts.CoffeeMaker.Status.BeverageCounterMilk": {
"value": 2
"ConsumerProducts.CoffeeMaker.Status.BeverageCounterHotWaterCups": {
"value": 25
"ConsumerProducts.CoffeeMaker.Status.BeverageCounterHotWater": {
"value": 4824,
"unit": "ml"
"settings": {
"BSH.Common.Setting.ChildLock": {
"value": false
"BSH.Common.Setting.PowerState": {
"value": "BSH.Common.EnumType.PowerState.Standby"
"programs": [
"ConsumerProducts.CoffeeMaker.Program.Beverage.Espresso",
"ConsumerProducts.CoffeeMaker.Program.Beverage.EspressoDoppio",
"ConsumerProducts.CoffeeMaker.Program.Beverage.Coffee",
"ConsumerProducts.CoffeeMaker.Program.Beverage.CaffeGrande",
"ConsumerProducts.CoffeeMaker.Program.Beverage.Cappuccino",
"ConsumerProducts.CoffeeMaker.Program.Beverage.LatteMacchiato",
"ConsumerProducts.CoffeeMaker.Program.Beverage.CaffeLatte",
"ConsumerProducts.CoffeeMaker.Program.Beverage.MilkFroth",
"ConsumerProducts.CoffeeMaker.Program.Beverage.WarmMilk",
"ConsumerProducts.CoffeeMaker.Program.Beverage.HotWater",
"ConsumerProducts.CoffeeMaker.Program.Beverage.XLCoffee",
"ConsumerProducts.CoffeeMaker.Program.Beverage.Ristretto",
"ConsumerProducts.CoffeeMaker.Program.Beverage.EspressoMacchiato",
"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Verlaengerter",
"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.KleinerBrauner",
"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.WienerMelange",
"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.FlatWhite",
"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.CafeConLeche",
"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.CafeAuLait",
"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.KoffieVerkeerd",
"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Americano",
"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.GrosserBrauner",
"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.VerlaengerterBraun",
"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Cortado",
"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Doppio",
"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.CafeCortado",
"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Kaapi",
"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Galao",
"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.Garoto",
"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.RedEye",
"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.BlackEye",
"ConsumerProducts.CoffeeMaker.Program.CoffeeWorld.DeadEye"
"issues":
EDIT by Jay: Code bitte immer über die Codefunktion im Editor einfügen.
