Hallo, ich habe ein Problem das der Präsenzmelder Errors in die Log Schreibt. Bei Verbindung steht das er mit MQTT verbunden ist. Ich weis also nicht was das Problem ist.
[06.10.2026 21:20] Websocket connected (id: 22 - open: 1)
[06.10.2026 21:21] Reconnecting mqtt broker (192.168.178.111)...
[06.10.2026 21:21] Mqtt not connected: keepalive timeout (keepalive)
[06.10.2026 21:21] Error websocket: (32, 'Websocket connection closed')
[06.10.2026 21:21] Websocket connection canceled (id: 22)
[06.10.2026 21:21] Websocket connected (id: 23 - open: 1)
[06.10.2026 21:21] Websocket connection canceled (id: 23)
[06.10.2026 21:21] Websocket connected (id: 24 - open: 1)
[06.10.2026 21:21] Websocket connected (id: 25 - open: 2)
[06.10.2026 21:21] Websocket connection canceled (id: 25)
[06.10.2026 21:21] Setting mqtt_broker to "192.168.178.111"
[06.10.2026 21:21] Setting mqtt_port to "1883"
[06.10.2026 21:21] Setting mqtt_reconnect to "30"
[06.10.2026 21:21] Setting mqtt_user to "mqtt-user"
[06.10.2026 21:21] Setting mqtt_pwd to "xxxx"
[06.10.2026 21:21] Setting mqtt_client_id to "xxx"
[06.10.2026 21:21] Setting mqtt_topic to "Praesenssensor_Wonhnzimmer_EG"
[06.10.2026 21:21] Setting mqtt_publish_interval to "300"
[06.10.2026 21:21] Setting mqtt_ssl to "False"
[06.10.2026 21:21] Setting mqtt_ha_discovery to "True"
[06.10.2026 21:21] Setting light_in_lux to "True"
[06.10.2026 21:21] Websocket connected (id: 26 - open: 2)
[06.10.2026 21:21] Error websocket: [Errno 104] ECONNRESET
[06.10.2026 21:21] Websocket connection canceled (id: 26)
[06.10.2026 21:21] Websocket connected (id: 27 - open: 2)
[06.10.2026 21:21] Connecting mqtt broker (192.168.178.111)...
[06.10.2026 21:21] Mqtt connected
[06.10.2026 21:21] Websocket connection canceled (id: 24)
[06.10.2026 21:21] Websocket connection canceled (id: 27)
[06.10.2026 21:21] Websocket connected (id: 28 - open: 1)
[06.10.2026 21:22] Error websocket: (32, 'Websocket connection closed')
[06.10.2026 21:22] Websocket connection canceled (id: 28)
[06.10.2026 21:22] Websocket connected (id: 29 - open: 1)
[06.10.2026 21:22] Websocket connection canceled (id: 29)
[06.10.2026 21:22] Websocket connected (id: 30 - open: 1)
[06.10.2026 21:22] Websocket connection canceled (id: 30)
[06.10.2026 21:22] Websocket connected (id: 31 - open: 1)
[06.10.2026 21:22] Websocket connection canceled (id: 31)
[06.10.2026 21:22] Websocket connected (id: 32 - open: 1)
[06.10.2026 21:22] Websocket connected (id: 33 - open: 2)
[06.10.2026 21:22] Websocket connection canceled (id: 33)
[06.10.2026 21:22] Websocket connected (id: 34 - open: 2)
[06.10.2026 21:22] Websocket connection canceled (id: 34)
[06.10.2026 21:22] Websocket connection canceled (id: 32)
[06.10.2026 21:22] Websocket connected (id: 35 - open: 1)
[06.10.2026 21:23] Websocket connection canceled (id: 35)
[06.10.2026 21:23] Websocket connected (id: 36 - open: 1)
[06.10.2026 21:23] Error websocket: (32, 'Websocket connection closed')
[06.10.2026 21:23] Websocket connection canceled (id: 36)
[06.10.2026 21:23] Websocket connected (id: 37 - open: 1)
[06.10.2026 21:23] Websocket connection canceled (id: 37)
[06.10.2026 21:23] Websocket connected (id: 38 - open: 1)
[06.10.2026 21:23] Websocket connected (id: 39 - open: 2)
[06.10.2026 21:23] Error websocket: [Errno 104] ECONNRESET
[06.10.2026 21:23] Websocket connection canceled (id: 38)
[06.10.2026 21:23] Websocket connection canceled (id: 39)
[06.10.2026 21:23] Setting mqtt_broker to "192.168.178.111"
[06.10.2026 21:23] Setting mqtt_port to "1884"
[06.10.2026 21:23] Setting mqtt_reconnect to "30"
[06.10.2026 21:23] Setting mqtt_user to "mqtt-user"
[06.10.2026 21:23] Setting mqtt_pwd to "xxx"
[06.10.2026 21:23] Setting mqtt_client_id to "xxx"
[06.10.2026 21:23] Setting mqtt_topic to "Praesenssensor_Wonhnzimmer_EG"
[06.10.2026 21:23] Setting mqtt_publish_interval to "300"
[06.10.2026 21:23] Setting mqtt_ssl to "False"
[06.10.2026 21:23] Setting mqtt_ha_discovery to "True"
[06.10.2026 21:23] Setting light_in_lux to "True"
[06.10.2026 21:23] Mqtt-broker not connected or disabled
[06.10.2026 21:23] Websocket connected (id: 40 - open: 1)
[06.10.2026 21:23] Websocket connection canceled (id: 40)
[06.10.2026 21:23] Websocket connected (id: 41 - open: 1)
[06.10.2026 21:23] Connecting mqtt broker (192.168.178.111)...
[06.10.2026 21:23] Mqtt not connected: OSError(104,) (connect)
[06.10.2026 21:24] Error websocket: (32, 'Websocket connection closed')
[06.10.2026 21:24] Websocket connection canceled (id: 41)
[06.10.2026 21:24] Setting mqtt_broker to "192.168.178.111"
[06.10.2026 21:24] Setting mqtt_port to "1883"
[06.10.2026 21:24] Setting mqtt_reconnect to "30"
[06.10.2026 21:24] Setting mqtt_user to "mqtt-user"
[06.10.2026 21:24] Setting mqtt_pwd to "xxx"
[06.10.2026 21:24] Setting mqtt_client_id to "xxx"
[06.10.2026 21:24] Setting mqtt_topic to "Praesenssensor_Wonhnzimmer_EG"
[06.10.2026 21:24] Setting mqtt_publish_interval to "300"
[06.10.2026 21:24] Setting mqtt_ssl to "False"
[06.10.2026 21:24] Setting mqtt_ha_discovery to "True"
[06.10.2026 21:24] Setting light_in_lux to "True"
[06.10.2026 21:24] Websocket connected (id: 42 - open: 1)
[06.10.2026 21:24] Error websocket: [Errno 104] ECONNRESET
[06.10.2026 21:24] Websocket connection canceled (id: 42)
[06.10.2026 21:24] Websocket connected (id: 43 - open: 1)
[06.10.2026 21:24] Connecting mqtt broker (192.168.178.111)...
[06.10.2026 21:24] Mqtt connected
[06.10.2026 21:24] Websocket connection canceled (id: 43)
[06.10.2026 21:24] Websocket connected (id: 44 - open: 1)
[06.10.2026 21:24] Websocket connection canceled (id: 44)
[06.10.2026 21:30] Websocket connected (id: 45 - open: 1)
[06.10.2026 21:30] Error websocket: (32, 'Websocket connection closed')
[06.10.2026 21:30] Websocket connection canceled (id: 45)
[07.10.2026 08:39] Restart
[07.10.2026 08:39] Start (Version 2.8.4 / 1.21.0 (MPU))
[07.10.2026 08:39] Radar: V2.44.24073110
[07.10.2026 08:39] Restarting sensor...
[07.10.2026 08:39] No BME280 found
[07.10.2026 08:39] Access point (ip: 192.168.4.1)
[07.10.2026 08:39] Scanning network...
[07.10.2026 08:39] SSID: "Wile E. Coyote / Road Runner" (0c:72:74:12:9d:93) -> RSSI: -70
[07.10.2026 08:39] SSID: "Solar-WiFi235W0763" -> RSSI: -71
[07.10.2026 08:39] SSID: "Wile E. Coyote / Road Runner" -> RSSI: -73
[07.10.2026 08:39] SSID: "Wile E. Coyote / Road Runner" -> RSSI: -74
[07.10.2026 08:39] SSID: "Wile E. Coyote / Road Runner" -> RSSI: -81
[07.10.2026 08:39] SSID: "Fritz-box-7490" -> RSSI: -82
[07.10.2026 08:39] SSID: "MagentaWLAN-8P73" -> RSSI: -89
[07.10.2026 08:39] SSID: "FRITZ!Box 7590 AT" -> RSSI: -90
[07.10.2026 08:39] SSID: "WLAN-JFJUVV" -> RSSI: -91
[07.10.2026 08:39] SSID: "DIRECT-N5CLX-6260 Series" -> RSSI: -93
[07.10.2026 08:39] Setting hostname to 9764a8
[07.10.2026 08:39] Connecting wifi Wile E. Coyote / Road Runner..
[07.10.2026 08:39] Wifi connected (ip: 192.168.178.102)
[07.10.2026 08:39] Connecting ntp-server...
[07.10.2026 08:39] Time set to 07.10.2026 08:39
[07.10.2026 08:39] Connecting mqtt broker (192.168.178.111)...
[07.10.2026 08:39] Mqtt connected
[07.10.2026 08:39] Websocket connected (id: 1 - open: 1)
[07.10.2026 08:40] Error websocket: (32, 'Websocket connection closed')
[07.10.2026 08:40] Websocket connection canceled (id: 1)
[07.10.2026 08:40] Websocket connected (id: 2 - open: 1)
[07.10.2026 08:40] Error websocket: [Errno 104] ECONNRESET
[07.10.2026 08:40] Websocket connection canceled (id: 2)
[07.10.2026 08:40] Websocket connected (id: 3 - open: 1)
[07.10.2026 08:40] Websocket connection canceled (id: 3)
[07.10.2026 08:40] Websocket connected (id: 4 - open: 1)
[07.10.2026 08:40] Websocket connection canceled (id: 4)
[07.10.2026 08:40] Websocket connected (id: 5 - open: 1)
[07.10.2026 08:40] OTA: cancel rollback
[07.10.2026 08:40] Websocket connection canceled (id: 5)
[07.10.2026 08:43] Websocket connected (id: 6 - open: 1)
[07.10.2026 08:44] Error websocket: (32, 'Websocket connection closed')
[07.10.2026 08:44] Websocket connection canceled (id: 6)
