Hallo Zusammen,
hab meinen alten Atom Echo wiede raus gekramt und möchte ihn für einfache Sprachansagen nutzen.
Wenn ich über Sprachassistenten, Stimme ausprobieren gehe, funktioniert es auch. Im Log steht nichts.
Wenn ich aber über Medien, Text-to-speech gehe oder in einer Automation, Text-to-speech wähle, funktioniert es nicht. Im Log steht folgendes:
[17:38:57][D][media_player:084]: 'M5Stack Atom Echo 0f7e5c' - Setting
[17:38:57][D][media_player:091]: Media URL: http://192.168.1.235:8123/api/esphome/ffmpeg_proxy/8465c6d92d8bc1f954deb9a193cfa307/m3epUpKAfukvDOwRKrqM5Q.wav
[17:38:57][D][media_player:097]: Announcement: yes
[17:38:57][D][voice_assistant:606]: Signaling stop
[17:38:57][D][voice_assistant:478]: State changed from STREAMING_MICROPHONE to STOP_MICROPHONE
[17:38:57][D][voice_assistant:485]: Desired state set to IDLE
[17:38:57][D][light:091]: 'M5Stack Atom Echo 0f7e5c' Setting:
[17:38:57][D][light:104]: State: ON
[17:38:57][D][light:079]: Brightness: 100%
[17:38:57][D][light:115]: Red: 0%, Green: 0%, Blue: 100%
[17:38:57][D][speaker_media_player:406]: State changed to ANNOUNCING
[17:38:57][D][voice_assistant:478]: State changed from STOP_MICROPHONE to STOPPING_MICROPHONE
[17:38:57][D][speaker_media_player.pipeline:114]: Reading WAV file type
[17:38:57][D][voice_assistant:478]: State changed from STOPPING_MICROPHONE to IDLE
[17:38:57][D][voice_assistant:624]: Event Type: 2
[17:38:57][D][voice_assistant:766]: Assist Pipeline ended
[17:38:57][D][ring_buffer:034][ann_read]: Created ring buffer with size 6000
[17:38:57][D][light:104]: State: OFF
[17:38:57][D][speaker_media_player.pipeline:124]: Decoded audio has 2 channels, 16000 Hz sample rate, and 16 bits per sample
[17:38:57][D][i2s_audio.speaker:102]: Starting
[17:38:57][D][i2s_audio.speaker:106]: Started
[17:38:57][D][ring_buffer:034][speaker_task]: Created ring buffer with size 3840
[17:39:02][D][i2s_audio.speaker:111]: Stopping
[17:39:02][D][i2s_audio.speaker:116]: Stopped
[17:39:02][D][voice_assistant:478]: State changed from IDLE to START_MICROPHONE
[17:39:02][D][voice_assistant:485]: Desired state set to START_PIPELINE
[17:39:02][D][light:091]: 'M5Stack Atom Echo 0f7e5c' Setting:
[17:39:02][D][speaker_media_player:406]: State changed to IDLE
[17:39:02][D][voice_assistant:207]: Starting Microphone
[17:39:02][D][ring_buffer:034]: Created ring buffer with size 16384
[17:39:02][D][voice_assistant:478]: State changed from START_MICROPHONE to STARTING_MICROPHONE
[17:39:02][D][voice_assistant:478]: State changed from STARTING_MICROPHONE to START_PIPELINE
[17:39:02][D][voice_assistant:228]: Requesting start
[17:39:02][D][voice_assistant:478]: State changed from START_PIPELINE to STARTING_PIPELINE
[17:39:02][D][voice_assistant:500]: Client started, streaming microphone
[17:39:02][D][voice_assistant:478]: State changed from STARTING_PIPELINE to STREAMING_MICROPHONE
[17:39:02][D][voice_assistant:485]: Desired state set to STREAMING_MICROPHONE
[17:39:02][D][voice_assistant:624]: Event Type: 1
[17:39:02][D][voice_assistant:627]: Assist Pipeline running
[17:39:02][D][voice_assistant:624]: Event Type: 9
[17:44:02][D][voice_assistant:180]: reset conversation ID
Das bringt mich aber nicht weiter.
Hat Jemand eine Idee?
