BLE (Bluetooth) Code für JK BMS V19 JK-PB2A16S20P, ESP32 und ESP-Home
Mit diesem ESP-Home Device kann man das JK-BMS auslesen und editieren.
substitutions:
  device_description: "Monitor and control a JK-BMS v19 via bluetooth"
  external_components_source: github://syssi/esphome-jk-bms@main
  # Please use "JK02_24S" if you own a old JK-BMS < hardware version 11.0 (hardware version >= 6.0 and < 11.0)
  # Please use "JK02_32S" if you own a new JK-BMS >= hardware version 11.0 (f.e. JK-B2A8S20P hw 11.XW, sw 11.26)
  # Please use "JK04" if you have some old JK-BMS <= hardware version 3.0 (f.e. JK-B2A16S hw 3.0, sw. 3.3.0)
  protocol_version: JK02_32S
esphome:
  friendly_name: ${name}
  comment: ${device_description}
  project:
    version: 3.0.0
  compile_process_limit: 1
esp32:
  board: wemos_d1_mini32
  framework:
    type: esp-idf
    advanced:
      sram1_as_iram: true
      minimum_chip_revision: 3.1
external_components:
  - source: ${external_components_source}
    refresh: 0s
wifi:
  ssid: "Dein Wlan"
  password: "4711"
  fast_connect: on
  min_auth_mode: WPA2
  manual_ip:
    static_ip: 192.168.47.102
    gateway: 192.168.47.1
    subnet: 255.255.255.0
    dns1: 192.168.47.1
  use_address: 192.168.47.102
  ap:
    ssid: "JKbms"
    password: "123456789"
captive_portal:
web_server:
api:
  encryption:
    key: "8lYeCiJ+/NpXBvKWvGg3/YVZ6u/OUpWN3To3OOhnfhc="
ota:
  platform: esphome
  on_begin:
    then:
      - switch.turn_off: ble_client_switch0
      - logger.log: "BLE connection suspended for OTA update"
logger:
  level: DEBUG
  logs:
    esp32_ble_tracker: INFO
    esp32_ble_client: INFO
# If you don't use Home Assistant please remove this `api` section and uncomment the `mqtt` component!
#modbus_controller:
# mqtt:                                   kein MQTT  <--------------
#   broker: !secret mqtt_host
#   username: !secret mqtt_username
#   password: !secret mqtt_password
#   id: mqtt_client
esp32_ble_tracker:
  scan_parameters:
    active: false
ble_client:
  - mac_address: A3:C1:58:07:D4:32  <-- MAC anpassen <------------------
jk_bms_ble:
  - ble_client_id: client0
    protocol_version: ${protocol_version}
    throttle: 5s
binary_sensor:
  - platform: jk_bms_ble
    balancing:
    charging:
    discharging:
    heating:
    online_status:
    dry_contact_1:
      name: "dry contact 1"
    dry_contact_2:
      name: "dry contact 2"
button:
    retrieve_settings:
      name: "retrieve settings"
    retrieve_device_info:
      name: "retrieve device info"
    retrieve_logbook:
    shutdown:
    restart:
    factory_reset:
number:
    jk_bms_ble_id: bms0
    balance_trigger_voltage:
      name: "balance trigger voltage"
    cell_count:
    total_battery_capacity:
      name: "total battery capacity"
    cell_voltage_overvoltage_protection:
      name: "cell voltage overvoltage protection"
    cell_voltage_overvoltage_recovery:
      name: "cell voltage overvoltage recovery"
    cell_voltage_undervoltage_protection:
      name: "cell voltage undervoltage protection"
    cell_voltage_undervoltage_recovery:
      name: "cell voltage undervoltage recovery"
    balancing_start_voltage:
      name: "balancing start voltage"
    voltage_calibration:
      name: "voltage calibration"
    current_calibration:
      name: "current calibration"
    power_off_voltage:
      name: "power off voltage"
    max_balance_current:
      name: "max balance current"
    max_charge_current:
      name: "max charge current"
    max_discharge_current:
      name: "max discharge current"
    smart_sleep_voltage:
      name: "smart sleep voltage"
    smart_sleep_delay:
      name: "smart sleep delay"
    emergency_duration:
      name: "emergency duration"
    cell_soc100_voltage:
      name: "cell soc100 voltage"
    cell_soc0_voltage:
      name: "cell soc0 voltage"
    cell_request_charge_voltage:
      name: "cell request charge voltage"
    cell_request_float_voltage:
      name: "cell request float voltage"
    cell_request_charge_voltage_time:
      name: "cell request charge voltage time"
    cell_request_float_voltage_time:
      name: "cell request float voltage time"
    re_bulk_soc:
    charge_overcurrent_protection_delay:
      name: "charge overcurrent protection delay"
    charge_overcurrent_protection_recovery_time:
      name: "charge overcurrent protection recovery time"
    discharge_overcurrent_protection_delay:
      name: "discharge overcurrent protection delay"
    discharge_overcurrent_protection_recovery_time:
      name: "discharge overcurrent protection recovery time"
    short_circuit_protection_delay:
      name: "short circuit protection delay"
    short_circuit_protection_recovery_time:
      name: "short circuit protection recovery time"
    charge_overtemperature_protection:
      name: "charge overtemperature protection"
    charge_overtemperature_protection_recovery:
      name: "charge overtemperature protection recovery"
    discharge_overtemperature_protection:
      name: "discharge overtemperature protection"
    discharge_overtemperature_protection_recovery:
      name: "discharge overtemperature protection recovery"
    charge_undertemperature_protection:
      name: "charge undertemperature protection"
    charge_undertemperature_protection_recovery:
      name: "charge undertemperature protection recovery"
    discharge_undertemperature_protection:
      name: "discharge undertemperature protection"
    discharge_undertemperature_protection_recovery:
      name: "discharge undertemperature protection recovery"
    mosfet_overtemperature_protection:
      name: "mosfet overtemperature protection"
    mosfet_overtemperature_protection_recovery:
      name: "mosfet overtemperature protection recovery"
    discharge_precharge_time:
      name: "discharge precharge time"
    heating_start_temperature:
      name: "heating start temperature"
    heating_stop_temperature:
      name: "heating stop temperature"
sensor:
    jk_bms_ble_id: bms0
    min_cell_voltage:
      name: "min cell voltage"
    max_cell_voltage:
      name: "max cell voltage"
    min_voltage_cell:
      name: "min voltage cell"
    max_voltage_cell:
      name: "max voltage cell"
    delta_cell_voltage:
      name: "delta cell voltage"
    average_cell_voltage:
      name: "average cell voltage"
    cell_voltage_1:
      name: "cell voltage 1"
    cell_voltage_2:
      name: "cell voltage 2"
    cell_voltage_3:
      name: "cell voltage 3"
    cell_voltage_4:
      name: "cell voltage 4"
    cell_voltage_5:
      name: "cell voltage 5"
    cell_voltage_6:
      name: "cell voltage 6"
    cell_voltage_7:
      name: "cell voltage 7"
    cell_voltage_8:
      name: "cell voltage 8"
    cell_voltage_9:
      name: "cell voltage 9"
    cell_voltage_10:
      name: "cell voltage 10"
    cell_voltage_11:
      name: "cell voltage 11"
    cell_voltage_12:
      name: "cell voltage 12"
    cell_voltage_13:
      name: "cell voltage 13"
    cell_voltage_14:
      name: "cell voltage 14"
    cell_voltage_15:
      name: "cell voltage 15"
    cell_voltage_16:
      name: "cell voltage 16"
    cell_resistance_1:
      name: "cell resistance 1"
    cell_resistance_2:
      name: "cell resistance 2"
    cell_resistance_3:
      name: "cell resistance 3"
    cell_resistance_4:
      name: "cell resistance 4"
    cell_resistance_5:
      name: "cell resistance 5"
    cell_resistance_6:
      name: "cell resistance 6"
    cell_resistance_7:
      name: "cell resistance 7"
    cell_resistance_8:
      name: "cell resistance 8"
    cell_resistance_9:
      name: "cell resistance 9"
    cell_resistance_10:
      name: "cell resistance 10"
    cell_resistance_11:
      name: "cell resistance 11"
    cell_resistance_12:
      name: "cell resistance 12"
    cell_resistance_13:
      name: "cell resistance 13"
    cell_resistance_14:
      name: "cell resistance 14"
    cell_resistance_15:
      name: "cell resistance 15"
    cell_resistance_16:
      name: "cell resistance 16"
    total_voltage:
    current:
    heating_current:
    power:
    charging_power:
    discharging_power:
    temperature_sensor_1:
      name: "temperature sensor 1"
    temperature_sensor_2:
      name: "temperature sensor 2"
    temperature_sensor_3:
      name: "temperature sensor 3"
    temperature_sensor_4:
      name: "temperature sensor 4"
    temperature_sensor_5:
      name: "temperature sensor 5"
    mosfet_temperature:
      name: "mosfet temperature"
    balancer_status_bitmask:
      name: "balancer status bitmask"
    state_of_charge:
      name: "state of charge"
    state_of_health:
      name: "state of health"
    capacity_remaining:
      name: "capacity remaining"
    full_charge_capacity:
      name: "full charge capacity"
    charging_cycles:
    total_charging_cycle_capacity:
      name: "total charging cycle capacity"
    total_runtime:
    balancing_current:
    emergency_time_countdown:
      name: "emergency time countdown"
    smart_sleep_countdown:
      name: "smart sleep countdown"
    charge_status_id:
      name: "charge status id"
    charge_status_time_elapsed:
      name: "charge status time elapsed"
    detail_log_entry_count:
      name: "detail log entry count"
    battery_type_id:
      name: "battery type id"
    uart1_protocols_enabled_bitmask:
      name: "uart1 protocols enabled bitmask"
    uart2_protocols_enabled_bitmask:
      name: "uart2 protocols enabled bitmask"
    uart3_protocols_enabled_bitmask:
      name: "uart3 protocols enabled bitmask"
    can_protocols_enabled_bitmask:
      name: "can protocols enabled bitmask"
switch:
    charging:
    discharging:
    balancer:
    emergency:
    heating:
    disable_temperature_sensors:
      name: "disable temperature sensors"
    display_always_on:
      name: "display always on"
    smart_sleep:
    disable_pcl_module:
      name: "disable pcl module"
    timed_stored_data:
      name: "timed stored data"
    charging_float_mode:
      name: "charging float mode"
    emergency_button_trigger:
      name: "emergency button trigger"
    dry_contact_alarm_intermittent:
      name: "dry contact alarm intermittent"
    discharge_overcurrent_protection_2:
      name: "discharge overcurrent protection 2"
    discharge_overcurrent_protection_3:
      name: "discharge overcurrent protection 3"
    gps_locked_charging:
      name: "gps locked charging"
    gps_locked_discharging:
      name: "gps locked discharging"
  - platform: ble_client
    name: "enable bluetooth connection"
select:
    uart1_protocol:
      name: "uart1 protocol"
    uart2_protocol:
      name: "uart2 protocol"
    uart3_protocol:
      name: "uart3 protocol"
    can_protocol:
      name: "can protocol"
    lcd_buzzer_trigger:
      name: "lcd buzzer trigger"
    dry1_trigger:
    dry2_trigger:
    multiplexed_port_mode:
    load_config_preset:
      name: "load config preset"
text_sensor:
    errors:
    errors_bitmask_hex:
      name: "errors bitmask hex"
    balancer_status:
    total_runtime_formatted:
      name: "total runtime formatted"
    charge_status:
    software_version:
    hardware_version:
    battery_type:
# IP Infos
  - platform: wifi_info
    ip_address:
      name: ESP IP Address
      icon: mdi:ip
    ssid:
      name: ESP Connected SSID
      icon: mdi:wifi-check
    mac_address:
      name: ESP Mac Wifi Address
    scan_results:
      name: ESP Latest Scan Results
      icon: mdi:wifi-refresh
    dns_address:
      name: ESP DNS Address
      icon: mdi:dns
Möglicherweise kann es wer brauchen. Grüße azim
