Home assistant wallpanel schaltet sich selbst aus
Seit ca. 1 Woche schaltet sich bei mir das wallpanel nach ca. 2 sec. immer wieder aus.
Hat hier noch jemand das Problem oder weis wo der Fehler sein könnte?
Nutzen tu ich den fully brwoser.
hier der Code
wallpanel:
  enabled: false
  hide_header: true
  hide_toolbar: true
  hide_sidebar: true
  fullscreen: true
  idle_time: 300
  screensaver_stop_navigation_path: /Tablet_Test/start?wp_enabled=true
  image_url: http://picsum.photos/${width}/${height}?random=${timestamp}
  image_fit: cover
  image_list_update_interval: 3600
  image_order: sorted
  image_excludes: []
  show_exif_info: false
  fetch_address_data: true
  exif_info_template: >-
    ${address.town|address.city!prefix=!suffix= //
    }${DateTimeOriginal!options=year:numeric,month:long}
  screensaver_entity: input_boolean.firescreensaver
  info_animation_duration_x: 30
  info_animation_duration_y: 11
  info_animation_timing_function_x: ease-in-out
  info_animation_timing_function_y: ease-in-out
  info_move_pattern: random
  info_move_interval: 0
  info_move_fade_duration: 2
  type: horizontal-stack
  cards:
    - type: vertical-stack
      cards:
        - type: custom:digital-clock
        - show_current: true
          show_forecast: true
          type: weather-forecast
          entity: weather.munchen_stadt
          forecast_type: daily
        - show_name: true
          show_icon: true
          show_state: true
          type: glance
          entities:
            - entity: sensor.naechsteabholung
            - entity: sensor.biotonne
            - entity: sensor.papiertonne
            - entity: sensor.restmuelltonne
          state_color: true
        - type: glance
          entities:
            - entity: sensor.eg_aussen_modul_temperatur
            - entity: sensor.sensor_terrasse_temperatur
        - type: glance
          entities:
            - entity: sensor.eg_dach_temperatur
            - entity: sensor.eg_1_stock_temperatur
            - entity: sensor.eg_temperatur
            - entity: sensor.eg_keller_temperatur
        - type: custom:atomic-calendar-revive
          enableModeChange: true
          entities:
            - entity: calendar.geburtstage
              icon: mdi:cake-variant
              showMultiDay: true
            - entity: calendar.feiertage_bayer
              showMultiDay: true
              icon: mdi:bed
            - entity: calendar.ferien_bayern
              maxDaysToShow: 0
              showMultiDay: true
              icon: mdi:account-school
          defaultMode: Event
          showDeclined: false
          hideFinishedEvents: false
          showDate: true
          firstDayOfWeek: 1
          showDescription: false
          showMonth: false
          showProgressBar: true
          showCurrentEventLine: false
          dimFinishedEvents: true
          calShowDescription: false
          disableCalEventLink: false
          disableCalLocationLink: false
          disableCalLink: false
          showDatePerEvent: false
          showTimeRemaining: false
          hoursOnSameLine: false
          showAllDayHours: false
          showNoEventsForToday: true
          showFullDayProgress: false
          showEventIcon: true
          maxDaysToShow: 3
So richtig verstehe ich das nicht. Für eine idle time 300, also 5min nehme ich an wird der Screensaver gestoppt und dann durch den input_boolean.firescreensaver wieder eingeschaltet. Hast du den input-boolean mal kontrolliert, was der macht oder wann der aktiv wird.
Im Fully Browser hast du Keep Screen on aktiviert? Oder ist der Screensaver von Fully aktiviert und leg sich sozusagen einfach darüber.
Wäre jetzt so das erste was mir einfällt.
ich versuche es zu erklären :slight_smile:
nach 5 min schaltet sich der screensaver ein - so war es die letzten Monate
der firescreensaver ist ein Helfer/ Schalter damit kann ich z.B. Prüfen ob der sreensaver an ist oder diesen auch ausschalten kann.
Bei Fully ist ist keep screen aus.
hab es so gemacht Next Level Tablet Dashboard
Simon hat aber im video keep screen on hast du das genauso gemacht. Ein paar Sekunden davor die Einstellungen auch?
Wenn du den Schalter betätigst (inputboolean) geht das Display direkt an?
sorry mein Fehler.
Fully ist wie im Video eingestellt nur ohne Bewegungsmelder brauch das nicht.
sobald ich den Schalter betätige geht der Screen an aber schaltet sich nach ca. 2-3 sec. wieder aus.
Das gleiche passiert auch wenn Du 5 min wartet sreen geht an und nach 2-3 sec wieder aus.
mhh, dann weiß ich leider auch so nicht weiter..
Gelöst
warum auch immer hatte ich hier den falschen Pfad drinnen stehen.
screensaver_stop_navigation_path:/Tablet_Test/start?wp_enabled=true
warum es davor gut halbes Jahr gegangen ist keine Ahnung.
