ich habe seit längerem schon Probleme mit dem Cloudflared Add-On in Home Assistant.
Habe schon alle möglich Foren und Dokumentationen durch aber ich bekomme den Tunnel einfach nicht mehr zum laufen.
Kurz gesagt ich bin ratlos.
Hier mal die Logs des Add-Ons.
Add-on: Cloudflared
Use a Cloudflare Tunnel to remotely connect to Home Assistant without opening any ports
Add-on version: 5.2.9
You are running the latest version of this add-on.
System: Home Assistant OS 14.2 (amd64 / qemux86-64)
Home Assistant Core: 2025.2.2
Home Assistant Supervisor: 2025.02.0
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
Log level is set to DEBUG
[17:42:04] DEBUG: Cloudflared log level set to "info"
[17:42:04] DEBUG: Checking connectivity to Cloudflare
[17:42:04] DEBUG: Checking region1.v2.argotunnel.com TCP port 7844
[17:42:04] DEBUG: Checking region1.v2.argotunnel.com UDP port 7844
[17:42:05] DEBUG: Checking region2.v2.argotunnel.com TCP port 7844
[17:42:05] DEBUG: Checking region2.v2.argotunnel.com UDP port 7844
[17:42:06] DEBUG: Checking api.cloudflare.com TCP port 443
[17:42:06] INFO: Using Cloudflare Remote Management Tunnel
[17:42:06] INFO: All add-on configuration options except tunnel_token will be ignored.
[17:42:06] INFO: Connecting Cloudflare Tunnel...
[17:42:06] DEBUG: cloudflared tunnel --no-autoupdate --metrics=0.0.0.0:36500 run --token=53fb6186-c5b9-41bc-8af5-gekürzt
Provided Tunnel token is not valid.
See 'cloudflared tunnel run --help'.
[17:42:06] WARNING: cloudflared crashed, halting add-on
[17:42:06] INFO: cloudflared stopped, restarting...
[17:42:06] INFO: Service nginx exited with code 0 (by signal 0)
Meine Konfiguration in der configuration.yaml
# Cloudflared Konfiguration
http:
cors_allowed_origins:
- https://google.com
- https://www.home-assistant.io
ip_ban_enabled: true
login_attempts_threshold: 3
use_x_forwarded_for: true
trusted_proxies:
- 172.30.33.0/24
Meine Konfiguration bei Cloudflare
Hat jemand von euch noch eine Idee, woran das Problem liegen könnte?
Danke schon mal für die Unterstützung!
