in meiner Zweitinstanz im Gartenhaus startet Zigbee2MQTT nicht mehr.
Das Protokoll gibt folgendes aus:
[11:30:53] INFO: e[32mPreparing to start…e[0m
[11:30:53] INFO: e[32mSocat not enablede[0m
[11:30:53] INFO: e[32mStarting Zigbee2MQTT…e[0m
Starting Zigbee2MQTT without watchdog.
[2025-03-04 11:30:56] e[32minfoe[39m: z2m: Logging to console, file (filename: log.log)
[2025-03-04 11:30:56] e[32minfoe[39m: z2m: Starting Zigbee2MQTT version 2.1.3 (commit #unknown)
[2025-03-04 11:30:56] e[32minfoe[39m: z2m: Starting zigbee-herdsman (3.2.7)
[2025-03-04 11:30:56] e[32minfoe[39m: zh:adapter:discovery: Matched adapter: {„path“:„/dev/ttyUSB0“,„manufacturer“:„Silicon Labs“,„serialNumber“:„0001“,„pnpId“:„usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0“,„vendorId“:„10c4“,„productId“:„ea60“} => zstack: path=/dev/ttyUSB0, score=4
[2025-03-04 11:30:56] e[32minfoe[39m: zh:zstack:znp: Opening SerialPort with {„path“:„/dev/ttyUSB0“,„baudRate“:115200,„rtscts“:false,„autoOpen“:false}
[2025-03-04 11:30:56] e[32minfoe[39m: zh:zstack:znp: Serialport opened
[2025-03-04 11:30:56] e[31merrore[39m: z2m: Error while starting zigbee-herdsman
[2025-03-04 11:30:56] e[31merrore[39m: z2m: Failed to start zigbee-herdsman
[2025-03-04 11:30:56] e[31merrore[39m: z2m: Check Zigbee2MQTT fails to start/crashes runtime | Zigbee2MQTT for possible solutions
[2025-03-04 11:30:56] e[31merrore[39m: z2m: Exiting…
[2025-03-04 11:30:56] e[31merrore[39m: z2m: Error: → ‚SREQ: ZDO - extAddGroup - {„endpoint“:242,„groupid“:2948,„namelen“:0,„groupname“:}‘ failed with status ‚(0xb2: APS_TABLE_FULL)‘ (expected ‚(0x00: SUCCESS)‘)
at /app/node_modules/.pnpm/zigbee-herdsman@3.2.7/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:258:27
at Queue.execute (/app/node_modules/.pnpm/zigbee-herdsman@3.2.7/node_modules/zigbee-herdsman/src/utils/queue.ts:36:20)
at ZnpAdapterManager.addToGroup (/app/node_modules/.pnpm/zigbee-herdsman@3.2.7/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:491:13)
at ZnpAdapterManager.start (/app/node_modules/.pnpm/zigbee-herdsman@3.2.7/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/manager.ts:102:9)
at ZStackAdapter.start (/app/node_modules/.pnpm/zigbee-herdsman@3.2.7/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:158:16)
at Controller.start (/app/node_modules/.pnpm/zigbee-herdsman@3.2.7/node_modules/zigbee-herdsman/src/controller/controller.ts:136:29)
at Zigbee.start (/app/lib/zigbee.ts:69:27)
at Controller.start (/app/lib/controller.ts:142:13)
at start (/app/index.js:161:5)
Ich benutze den Sonoff Zigbee 3.0 USB Dongle Plus-P.
In der GUI-Konfiguration steht:
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: "-d -d"
log: false
mqtt: {}
serial:
port: >-
/dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
adapter: zstack
In der zigbee2mqtt/configuration.yaml steht:
homeassistant:
enabled: true
advanced:
network_key:
- 181
[noch einige Zahlen mehr]
pan_id: 46027
ext_pan_id:
- 250
log_syslog:
app_name: Zigbee2MQTT
eol: /n
host: localhost
localhost: localhost
path: /dev/log
pid: process.pid
port: 514
protocol: udp4
type: '5424'
last_seen: ISO_8601_local
mqtt:
server: mqtt://core-mosquitto:1883
user: addons
password: [hier steht das Passwort]
serial:
port: >-
adapter: zstack
frontend:
enabled: true
port: 8099
device_options: {}
devices:
[hier ist die Auflistung der Geräte]
availability:
enabled: true
version: 4
Der Dongle war nie mit einer anderen HA-Instanz verbunden oder mit ZHA gekoppelt und lief jetzt über ein Jahr lang vollkommen stabil ohne Probleme. Das Rückspielen des Backups von vor dem letzten Update hat auch nichts gebracht.
Kann jemand etwas mit der Fehlermeldung anfangen?
Beste Grüße
