Hallo, nutze HA 2025.5, Zigbee2MQTT und den SLZB-06 über PoE und ca. 50 Zigbee Geräte. Seit ein paar Wochen sind ca. 80 % der Geräte immer offline.
Woran kann es liegen? Schon fast alles probiert… ob Standort Wechsel vom SLZB, neuste Firmware vom Stick, jeweils neuste Version im HA etc… Freue mich über Tipps.
Hier ein Logausschnitt:
[2025-06-08 13:15:10] z2m: Failed to ping 'LichtStern' (attempt 1/1, ZCL command 0xbc026efffe676378/1 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Timeout - 25227 - 1 - 6 - 0 - 1 after 10000ms))
[2025-06-08 13:15:14] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/IkeaVindstyrka', payload '{"humidity":58,"identify":null,"last_seen":"2025-06-08T13:15:14+02:00","linkquality":87,"pm25":1,"temperature":20,"update":{"installed_version":16777233,"latest_version":16777233,"state":"idle"},"voc_index":14}'
[2025-06-08 13:15:22] z2m: Failed to ping 'SteckdoseSternBuero' (attempt 1/1, ZCL command 0xa4c138ff952dbe67/1 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Timeout - 2628 - 1 - 7 - 0 - 1 after 10000ms))
[2025-06-08 13:15:26] z2m: Failed to ping 'LichtSchlafDecke' (attempt 1/1, ZCL command 0x54ef441000ee61e3/1 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205)))
[2025-06-08 13:15:38] z2m: Failed to ping 'LichtTVSchlaf' (attempt 1/1, ZCL command 0xa4c1388bd4a1c8d1/1 genBasic.read(["zclVersion"], {"timeout":10000,"disableResponse":false,"disableRecovery":true,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Timeout - 64198 - 1 - 9 - 0 - 1 after 10000ms))
[2025-06-08 13:15:40] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/SteckdoseWallFlurOben', payload '{"auto_off":false,"button_lock":"OFF","charging_limit":2,"charging_protection":"OFF","consumption":6.577538967132568,"current":0,"device_temperature":28,"energy":6.58,"last_seen":"2025-06-08T13:15:40+02:00","led_disabled_night":false,"led_indicator":"OFF","linkquality":76,"operation_mode":"control_relay","overload_protection":3840,"power":0,"power_on_behavior":null,"power_outage_count":18,"state":"OFF","update":{"installed_version":30,"latest_version":30,"state":"idle"},"voltage":234.08}'
[2025-06-08 13:15:44] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/IkeaVindstyrka', payload '{"humidity":58,"identify":null,"last_seen":"2025-06-08T13:15:44+02:00","linkquality":87,"pm25":1,"temperature":20,"update":{"installed_version":16777233,"latest_version":16777233,"state":"idle"},"voc_index":13}'
[2025-06-08 13:15:46] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/IkeaKuecheButton', payload '{"battery":74,"identify":null,"last_seen":"2025-06-08T13:15:46+02:00","linkquality":58,"update":{"installed_version":604241925,"latest_version":604241925,"state":"idle"}}'
[2025-06-08 13:15:46] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"IkeaKuecheButton","ieee_address":"0xec1bbdfffe46a5af"},"type":"device_announce"}'
[2025-06-08 13:16:01] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/IkeaKuecheLichtRechts/availability', payload '{"state":"online"}'
[2025-06-08 13:16:01] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/IkeaKuecheLichtRechts', payload '{"brightness":254,"effect":null,"identify":null,"last_seen":"2025-06-08T13:16:01+02:00","level_config":{"current_level_startup":"previous","on_level":"previous","on_off_transition_time":5},"linkquality":10,"power_on_behavior":"on","state":"OFF","update":{"installed_version":587753009,"latest_version":587753009,"state":"idle"}}'
[2025-06-08 13:16:06] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/IkeaKuecheLichtLinks/availability', payload '{"state":"online"}'
[2025-06-08 13:16:06] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/IkeaKuecheLichtLinks', payload '{"brightness":254,"effect":null,"identify":null,"last_seen":"2025-06-08T13:16:06+02:00","level_config":{"current_level_startup":"previous","on_level":"previous","on_off_transition_time":5},"linkquality":51,"power_on_behavior":"on","state":"ON","update":{"installed_version":587753009,"latest_version":587753009,"state":"idle"}}'
[2025-06-08 13:16:14] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/IkeaVindstyrka', payload '{"humidity":58,"identify":null,"last_seen":"2025-06-08T13:16:14+02:00","linkquality":87,"pm25":1,"temperature":20,"update":{"installed_version":16777233,"latest_version":16777233,"state":"idle"},"voc_index":13}'
[2025-06-08 13:16:19] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/SteckdoseWallFlurOben', payload '{"auto_off":false,"button_lock":"OFF","charging_limit":2,"charging_protection":"OFF","consumption":6.577538967132568,"current":0,"device_temperature":28,"energy":6.58,"last_seen":"2025-06-08T13:16:19+02:00","led_disabled_night":false,"led_indicator":"OFF","linkquality":54,"operation_mode":"control_relay","overload_protection":3840,"power":0,"power_on_behavior":null,"power_outage_count":18,"state":"OFF","update":{"installed_version":30,"latest_version":30,"state":"idle"},"voltage":234.08}'
[2025-06-08 13:16:21] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/IkeaKuecheLichtRechts', payload '{"brightness":254,"effect":null,"identify":null,"last_seen":"2025-06-08T13:16:21+02:00","level_config":{"current_level_startup":"previous","on_level":"previous","on_off_transition_time":5},"linkquality":10,"power_on_behavior":"on","state":"OFF","update":{"installed_version":587753009,"latest_version":587753009,"state":"idle"}}'
[2025-06-08 13:16:26] z2m: Failed to read state of 'IkeaKuecheLichtRechts' after reconnect (ZCL command 0x588e81fffe61ac45/1 genOnOff.read(["onOff"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Timeout - 14985 - 1 - 10 - 6 - 1 after 10000ms))
[2025-06-08 13:16:28] z2m: Request 'zigbee2mqtt/bridge/request/device/interview' failed with error: 'interview of 'TempLuftBuero' (0x881a14fffef492c0) failed: Error: Interview failed because can not get active endpoints ('0x881a14fffef492c0')'
[2025-06-08 13:16:28] frontend:api: Error: interview of 'TempLuftBuero' (0x881a14fffef492c0) failed: Error: Interview failed because can not get active endpoints ('0x881a14fffef492c0') (transaction: fx1dx-1)
[2025-06-08 13:16:28] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/response/device/interview', payload '{"data":{},"error":"interview of 'TempLuftBuero' (0x881a14fffef492c0) failed: Error: Interview failed because can not get active endpoints ('0x881a14fffef492c0')","status":"error","transaction":"fx1dx-1"}'
[2025-06-08 13:16:32] z2m: Failed to read state of 'IkeaKuecheLichtLinks' after reconnect (ZCL command 0x842e14fffe5d750b/1 genOnOff.read(["onOff"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Timeout - 20101 - 1 - 11 - 6 - 1 after 10000ms))
[2025-06-08 13:16:35] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/IkeaKuecheLichtLinks', payload '{"brightness":254,"effect":null,"identify":null,"last_seen":"2025-06-08T13:16:35+02:00","level_config":{"current_level_startup":"previous","on_level":"previous","on_off_transition_time":5},"linkquality":54,"power_on_behavior":"on","state":"ON","update":{"installed_version":587753009,"latest_version":587753009,"state":"idle"}}'
[2025-06-08 13:16:58] z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/SteckdoseWallFlurOben', payload '{"auto_off":false,"button_lock":"OFF","charging_limit":2,"charging_protection":"OFF","consumption":6.577538967132568,"current":0,"device_temperature":28,"energy":6.58,"last_seen":"2025-06-08T13:16:58+02:00","led_disabled_night":false,"led_indicator":"OFF","linkquality":51,"operation_mode":"control_relay","overload_protection":3840,"power":0,"power_on_behavior":null,"power_outage_count":18,"state":"OFF","update":{"installed_version":30,"latest_version":30,"state":"idle"},"voltage":234.08}'
