Hallo Freude,
ich habe meinen HAGreen am Anfang folgendes installiert:
Advanced & Web Terminal, dann SH neustart. HACS nach Videoanleitung installiert.
mqtt-Broker, Benutzer angelegt mit Passwort ohne Admin, wieder neustart.
Bei Geräte/Dienste mqtt-Broker auf Konfigurieren und dann neu konfigurieren angewählt.
Benutzername und PW eingegeben auf weiter und ok geklickt. Danach wieder neustart.
Nach dem Neustart mqtt auf start gedrückt.
Protokoll zeigt an:
[14:59:11] INFO: SSL is not enabled cont-init: info: /etc/cont-init.d/mosquitto.sh exited 0 cont-init: info: running /etc/cont-init.d/nginx.sh cont-init: info: /etc/cont-init.d/nginx.sh exited 0 s6-rc: info: service legacy-cont-init successfully started s6-rc: info: service legacy-services: starting services-up: info: copying legacy longrun mosquitto (no readiness notification) services-up: info: copying legacy longrun nginx (no readiness notification) s6-rc: info: service legacy-services successfully started [14:59:13] INFO: Starting NGINX for authentication handling… [14:59:14] INFO: Starting mosquitto MQTT broker… 2024-12-20 14:59:14: Warning: Mosquitto should not be run as root/administrator. 2024-12-20 14:59:14: mosquitto version 2.0.18 starting 2024-12-20 14:59:14: Config loaded from /etc/mosquitto/mosquitto.conf. 2024-12-20 14:59:14: Loading plugin: /usr/share/mosquitto/go-auth.so 2024-12-20 14:59:14: ├── Username/password checking enabled. 2024-12-20 14:59:14: ├── TLS-PSK checking enabled. 2024-12-20 14:59:14: └── Extended authentication not enabled. 2024-12-20 14:59:14: Opening ipv4 listen socket on port 1883. 2024-12-20 14:59:14: Opening ipv6 listen socket on port 1883. 2024-12-20 14:59:14: Opening websockets listen socket on port 1884. 2024-12-20 14:59:14: mosquitto version 2.0.18 running 2024-12-20 14:59:14: New connection from ::1:38818 on port 1883. 2024-12-20 14:59:14: Client disconnected due to protocol error. [14:59:17] INFO: Successfully send discovery information to Home Assistant. 2024-12-20 14:59:18: New connection from 172.30.32.1:41757 on port 1883. 2024-12-20 14:59:18: New client connected from 172.30.32.1:41757 as 7i0u1O9c1B3twZFKXOJJZC (p2, c1, k60, u’mqtt-user’). [14:59:18] INFO: Successfully send service information to the Supervisor. 2024-12-20 14:59:37: New connection from 172.30.32.2:34516 on port 1883. 2024-12-20 14:59:37: Client closed its connection.
2024-12-20 15:01:37: New connection from 172.30.32.2:60972 on port 1883. 2024-12-20 15:01:37: Client closed its connection.
2024-12-20 15:03:37: New connection from 172.30.32.2:44586 on port 1883. 2024-12-20 15:03:37: Client closed its connection
Die letzten zwei Zeilen erscheinen alle 2 Minuten.
Frage an euch: Hat jemand ein Tipp zur Lösung, ich bin schon am Verzweifeln.
Gruß Heinz
